I was wondering if there is a way to map a a Key sequence to a button in a Plugin? I can get to the Plug in page I need, I just want to directly press a button on a specific plugin.
Thanks in advance!
Thanks in advance!
geposted Mon 05 Nov 12 @ 1:21 pm
example: var '$shift' ? effect 'backspin' active : effect 'beatgrid' active
button on = beatgrid & shift+button on = backspin
geposted Mon 05 Nov 12 @ 1:40 pm
I don't think that is what he means. You can simply do this for audio effects:
effect 'overloop' button 2
For video effects it is:
video_fx_select 'SlideShow' & video_fx_button 1
Video Transitions are the same principle, using video_transition instead of video_fx.
'Other' plugins cannot be done programatically, however some plugin authors implement a VDJScript variable you can set to simulate a button press.
geposted Tue 06 Nov 12 @ 12:13 am
also if it's a VST the buttons are all mapped with "effect slider" eg
button up - effect "effect_name" slider 10 0%
button down - effect "effect_name" slider 10 100%
toggling is done with
effect "effect_name" slider 10 0% ? effect "effect_name" slider 10 100% : effect "effect_name" slider 10 0%
and momentary is
down ? effect "effect_name" slider 10 100% : effect "effect_name" slider 10 0%
and momentary is
geposted Tue 06 Nov 12 @ 12:55 am
Sorry I sent you guys on a wild goose chase, Scott is right, I was asking about plugins on the "Others" page.
Thanks for all the great advice! Computer was packed or I would have sent a screen shot.
geposted Tue 06 Nov 12 @ 1:36 pm
I can add a command for that :)
geposted Wed 07 Nov 12 @ 11:04 am
