hello
I have virtual dj version 7.05 I just noticed that you have a new version or update, a friend of mine used to have version 6.something and when he downloaded the new version all his database got messed up tags that he had corrected manually got lost bpm scans on most of the tracks got lost also, so the question is this: this si a regular issue we should expect when updating our software versions? or what should we do to ensure that when we download and install this update our database wont get messed up and will stay the way it is
thanks, hope I explained myself
geposted Tue 06 Nov 12 @ 7:30 pm
grupofarra wrote :
hello
I meant when he installed the new version
geposted Tue 06 Nov 12 @ 11:38 pm
Ive been using VDJ since 5. Something and its always been good. Id say something went wrong with his system. To be sure your safe make a backup of you database (the xml file) or better yet just make a backup of the VDJ folder on your C drive.
Hope that helps
Huey
Hope that helps
Huey
geposted Wed 07 Nov 12 @ 12:01 am
thanks for response
I reviewed virtual dj changes wiki and I dont see significant changes that are helpful for me at the moment so I'll rather wait until a major update is released
thanks anyway
thanks anyway
geposted Sun 11 Nov 12 @ 2:31 pm
7.3 is out now!
Pretty big change...
geposted Sun 11 Nov 12 @ 3:10 pm
