Forum: Old versions
Topic: Adding song Field2 to my skin
I use Mixed in key and needed to use Field2 to store the Key information. I would like to show Field 2 on the deck that the track is loaded to, but I can't find a text element or VDJ verb that will display the Field2 value. Did I miss something?
I know how to change the text from Key to MIK. I just need to change the command form %camelot to something like %Field2.
I do know Comments works, but I have ALLOT of comments used for other reasons...
geposted Tue 06 Nov 12 @ 9:07 pm
use ..
<textzone deck="1">
<text ........format="`get loaded_song 'field2'`"/>
</textzone>
There is a special character (`) in the above script. Better copy-paste it.
Awesome, thank you. I tried
format="MIK`get loaded_song 'field2'`"/>
I get the MIK but no result, did I break it?
Still not working, so here is what I tried:
<textzone deck="1">
<pos x="320" y="200"/>
<size width="63" height="14"/>
<text font="ARIAL GREEK" size="17" color="#28acff" weight="bold" align="left" format="`get loaded_song 'field2'`"/>
</textzone>
and I don't get the Field 2 result. I will work with it some more. But what I was trying earlier was:
<textzone deck="1">
<text font="ARIAL GREEK" size="17" color="#28acff" weight="bold" align="left" format="MIK`get loaded_song 'field2'`"/>
</textzone>
I will get the MIK with this, but no result next to it.
Yeap, you re right. It doesnt work :) I rarely use those for skins, so i had to refresh my memory. In the browser you see Field1 and Field2, but for the database those are named as User1 and User2 fields.
so the correct format is ..
`get loaded_song 'user2'`
From Wiki Page http://www.virtualdj.com/wiki/VDJscript_verbs.html
Quote :
get loaded_song : get a property from the song loaded on the deck: "deck 2 get loaded_song 'album'" - Properties: Icon, Title, Author (Artist), Album, Genre, BPM, Key, Length, Bitrate, Year, Comment, PlayCount, FirstSeen, FirstPlay, LastPlay, Drive, Filepath, Filename, Filetype, Filesize, Filedate, LinkedVideo, KeyNumeric, Composer, BPMCompat, KeyCompat, Stars, User1, User2, LoadedOn
AH, I was looking at that, but never came to that conclusion. Thanks again man!
