Forum: Video Discussion
Topic: Video Recording Tip for Best Picture recording resolution
I ran across this problem while trying to record video and wanted to share how I resolved it.......If u wanna record video mixes in High Definition or High Quality you will need a video card with two (display) outputs and will need to set the video to the secondary display....alternatively u can increase the video window for better picture...I also recommend using a video card with 1GB or more RAM
geposted Wed 07 Nov 12 @ 6:14 pm
Hello Pls, can anyone help me out on how to use virtual dj pro full to record a full HD video like 1080 by 720p. Thanks pls help me out
Or how do I increase the video window if i want to do that? and which video card will you recommend for me to buy? pls help asap
Go to www.fraps.com and buy the program. Its the best way to record and its pretty easy on the Cpu......
Enjoy
Huey
hello how can i save my video mix with vestax vci 400 using virtual Dj ???
please i hope to get the answer as soon as possible thanx
DJ Petro, read the posts above
Thanks Huey, I'm going to download the trial version and see if fraps works for me. The home page says it works best with Nvidia GeForce cards so I'm excited to see the results.
Cheers
Cheers
I really recommend you fraps for your video sessions, it's excellent.
Hallo gentlemen
I downloaded the fraps trial version, but when i tried to record the video it just showed me 22 on the screen corner and the video was in like slow motion. Anyway you guyz can help me with the vdj setup, registry tool setup, video record fps, fraps setup. What codec should i use? Please.. Thanks
Well I hope fraps has been working for y'all, I've found something even better and I recommend it more the Fraps. It's called "Bandicam ", has a lot more features and works great!!
Enjoy
Huey
Enjoy
Huey
Can you explain the settings you use for Badicam to capture recordings with VDJ?
Thanks!
hey guys while am recording a video i need my picture to appear on the screen, what should i do? help me please
how can u record an image
