Forum: Old versions
Topic: Reloop Terminal Mix 4 channel mapping issue
Hi,
Just got a TM 4 and all buttons / faders are responding out of the box. The issue i have is channel/eq 1 and 2 are correct on the controller
but in VDJ the two left channel/eq 3 & 1 are responding
I looked in the mapper file but don't see where I can adjust. I clicked "new" to see what the fader value is and VOLUME appeared. Should I adjust there? Thanks for your help in advanced.
geposted Thu 08 Nov 12 @ 11:18 pm
djranes wrote :
Reloop TM4 has 3>1><2<4 skin itself. Simply install the VDJ LE (TM4) that came with it. Locate the skin from VDJ skin folder and extract all of it within that folder. Then you can now remove the VDJ LE (TM4) if you wish to from your system. Removing the LE without extracting it 1st will also remove the TM4 skin.
I already have VDJ 7 PRO on my PC. Can I just install the LE on another PC and take out the skin?
I installed it on another PC and transferred the Reloop folder over. Works perfectly! Thanks djranes!
