I have a Rane SL3. I want to configure Deck 1 Deck 2 and Aux Output for the sample and also I want the Aux In be able record when I go out from my mixer. I have everything connect right but its not working. Can someone help me?
geposted Fri 09 Nov 12 @ 11:34 am
Normaly if RANE offer propper driver ;-) you have just to select at VDJ Config - Soundcard the following.
Input - None, if you don't use TimeCode.
Output - External Mixer (3Lines)
Soundcard - 4Out ---> beside select your soundcard
Now it should be:
Deck 1 -> Output 1&2
Deck 2 -> Output 3&4
Sampler -> Output -> 5&6
When you now have connected the related outputs on soundcard side with your mixer inputs it should work!
Now it should be:
geposted Tue 13 Nov 12 @ 4:07 pm
Hi anyone
I Just bought a Denon DN-MC6000 controller, but for some reason I cant seem to get it to control V-DJ on my Imac, I tried every setting I can think of but it still dose not controls anything on J-Dj, can someone help me please.
Thanks
Thanks
geposted Sat 17 Nov 12 @ 2:12 pm
If your MC6000 didn't come with VirtualDJ LE included then you will need to purchase the full VirtualDJ Professional to be able to use it with VirtualDJ: http://www.virtualdj.com/buy/index.html
You can try it before purchasing in the latest Home FREE for 10 minutes at a time: http://www.virtualdj.com/download/free.html
Please see http://www.virtualdj.com/wiki/DN-MC6000.html
geposted Sat 17 Nov 12 @ 2:19 pm
Yes my MC6000 came with VirtualDJ LE included but the controller just dose not control anything in J-dj, so the controller is just here sitting on my desk doing notting, is there a driver that I need to install?
geposted Sat 17 Nov 12 @ 2:29 pm
You may have changed the MIDI channels that it operates on from the default. Please see the troubleshooting section of the above link: http://www.virtualdj.com/wiki/DN-MC6000.html (It won't work if you have changed the MIDI channels.)
Also, make sure that you have the most recent version of VirtualDJ LE installed. Please register your LE serial number on your profile page http://www.virtualdj.com/users/edit.html and then go to the Download Center to download any updates: http://www.virtualdj.com/download/updates.html
Make sure that you have the latest firmware and drivers installed from http://www.denondj.com
geposted Sat 17 Nov 12 @ 3:13 pm
Hi there do you know about the remote monitoring software whic is desktopgate , it makes monitoring contoling and management the other machine, can i use the software on apple ?
geposted Fri 11 Jan 13 @ 4:24 am
You would need to ask the manufacturer of the software that question. From Google search, it appears to be a Windows PC only product.
However, there are other remote control software solutions available for Mac though - To find some of these, try search Google for: mac remote desktop
If you are looking to remote control VirtualDJ on another computer and have an iPhone/iPad/iPod Touch then the best solution is our native remote control app iRemote: http://www.virtualdj.com/wiki/What%20is%20iRemote.html
Please also open your own new topic rather than hi-jacking an existing one that is not related to your question in any way. Your question has nothing to do with the original topic, which is about configuring the SL3 sound card.
To open a new topic, please click on the pen and paper icon at the top of the forum topic list page.
geposted Fri 11 Jan 13 @ 4:32 am
