djmikekc wrote :
I suppose it's the price of progress, but I HATE the new search. I have been lightning fast searching tracks since 4.3, but now I have to take extra time to start with a quotation mark? Oh well, boo hoo.
Also the results only pertain to the current folder. Not cool. Why not at least keep the results view the same, ie. the results from the selected folder above the line, and all others below the line?
Oh and everything pertaining to browsing / searching is slow... Grrr.
It does sound noticeably better, even on the crappy systems I have to plug into.
I am hoping to see a registry value allowing us to choose the old or new search method!
That is not how my search reacts at all, my search results are exactly the same as before except I can type rain purple instead of just purple rain. If you get it sorted, the new search is VERY handy
geposted Sat 17 Nov 12 @ 11:41 pm
i have noticed with the recent 7.3 update as stated the search engine is a little different ..i have noticed this with my library .i use to be able to type in the search line 14 - b and it ould take me to that precise area withinthat folder .. it no longer does this does this so now i have to scroll down the list to get to the b's in section 14 .
Any views on this ...
geposted Sun 18 Nov 12 @ 4:16 am
Especially setting to focus on the search field or clearing it is ridiculously slow and will freeze the whole application. To reproduce (at least with me):
- Search a term
- press backspace, its gonna be the last letter that will freeze VDJ
or
- Search a term
- set the focus of the search input
- Re-set the focus on the search input, this will clear it and again freeze VDJ
geposted Sun 18 Nov 12 @ 4:24 am
adam2410 wrote :
How or where can I get VDJ 7.2 BACK? I just updated to 7.3 and I am disappointed.
I am using VDJ with Numark Mixdeck on MacBook Pro.
after update to 7.3 i noticed the following problems
--- When I start VDJ - It does not remember sound-card configuration. i have to go to configuration in prefs and hit apply.
--- It froze on me for the THIRD TIME when i tried to apply sound-card configuration.
--- I am using VDJ PRO version and I will not feel like PRO DJ on tomorrow's gig waiting for the software to crash (DISASTER) while having people dancing on the floor.
Adam, just get in touch with support using a support ticket and they'll give you version 7.2 back. Obviously, it's a silly thing to say now, but it's always a good idea to keep all the versions just in case you ever want to go back.
geposted Sun 18 Nov 12 @ 9:06 am
- Search a term
or
- Search a term
- Search a term
or
- Search a term
No issues with search here, performs just as well as it did before but now love to be able to search for artist and track name in one hit.
geposted Sun 18 Nov 12 @ 9:12 am
Had a 8 hour job last Night at a 30 year birthday party and had no problems at all
Thanks vdj team for a good job
geposted Sun 18 Nov 12 @ 2:03 pm
Thanks for the update! The multi-field search update I am really pleased with!
geposted Sun 18 Nov 12 @ 3:12 pm
quick question before i download the update.. it took me forever to figure out the sound setup for this mac book pro with the pioneer cdj 400's.. will the update keep the configurations that i already have?
thanks
thanks
geposted Sun 18 Nov 12 @ 9:53 pm
Hi Trey47, mine did
geposted Sun 18 Nov 12 @ 11:10 pm
This is a GREAT update. Improved sound quality is terrific and optional limiting is also stellar. Thank you guys!
geposted Mon 19 Nov 12 @ 3:10 am
I installed this over 7.0.x and seems ok. But would this update/version do better if installed after a registry wipe and uninstall?
Just wondering to give us a common base to start.
geposted Mon 19 Nov 12 @ 8:57 am
No need to wipe anything (unless you have serious issues that cannot be solved).
As per previous releases just install over the top of the current version.
Keith
Keith
geposted Mon 19 Nov 12 @ 9:05 am
When I create a loop, and then hit "cue", the loop shuts off. I don't remember losing the loop in older versions.
I want to create a loop, and then hit cue to get it ready for when I'm going to mix it into a song by hitting "play".
Perhaps with the update something got turned off or on that I can merely re-click to get that loop holding in place?
Anyone know?
Anyone know?
geposted Mon 19 Nov 12 @ 9:16 am
Goto Config-->Performances tab ->Safe mode.
Uncheck that (if checked) and try again.
geposted Mon 19 Nov 12 @ 9:25 am
Zamooda wrote :
Using the Denon MC6000. No issues other than that and its not really an issue just was wondering why it was happening. Sounds amazing.
Dev staff wrote :
What controller are you using?
Try to raise the registry value JogScratchLatency, to 2048 or even 4096 and see if it helps.
Zamooda wrote :
Can someone please address the "underwater effect" you hear while cueing a track; you can also hear it while scratching. Again this was not happening in any other version or update only 7.3
Also using the Denon MC-6000, but I heard the same thing using a Denon Dn-X600 (soundcard) & S-3700s. I tried increasing JogScratchLatency, but I haven't had any luck getting rid of the "underwater effect". I uninstalled 7.3 and reinstalled 7.0.5 just to make sure that I just didn't notice it before . . . 7.0.5 didn't do it. Still using 7.3 despite this, since all the other good stuff you guys added makes this issue seem a little unimportant.
geposted Mon 19 Nov 12 @ 9:39 am
Adam, check the folder where your browser stores downloaded files. On a Mac, it is probably something like [HOME]/Documents/downloads
Unless you specifically deleted the file after installing it last time, it is likely still there and should be recognizable by file-name.
Hope that helps,
-Frd
geposted Mon 19 Nov 12 @ 10:16 am
So far, I think this update fixes the automix glitch that 7.2 (plus other 7.x versions) had.
But like others, while not playing a track, the cpu is about 20% when color waves enable.
geposted Mon 19 Nov 12 @ 12:21 pm
It didn't help the loop from becoming "turned off" when I hit the cue button.
I can't create a loop, and then put it in cue mode to wait for the right part of the song that's playing to mix my loop into it. I do that alot. :(
geposted Mon 19 Nov 12 @ 12:46 pm
Hmmm not sure what you re after, but maybe your CUE button is assigned as cue_button, meaning that it depends on the play_mode (Pioneer or Numark play mode).
Create a keyboard shortcut as ..
play_mode "Pioneer" ? play_mode "Numark" : play_mode "Pioneer"
that toggles between those modes and see if one or the other mode has the desired behavior for the CUE button.
geposted Mon 19 Nov 12 @ 1:40 pm
Speedy53 wrote :
Not yet.
shaungreen212 wrote :
Native support for denon 3900 in midi mode?
Not yet.
7.4?? Please. I want to switch from serato back to VDJ.
No complaints though, you guys are killing it. We appreciate the team listening to the consumers.
geposted Mon 19 Nov 12 @ 3:54 pm
