Topic: [NEW] VirtualDJ 7.3 - Page: 19
Ok when is VDJ 8 comming out????? I know there's no answer for that but please hurry up! VDJ 7.3 works fine so far for me but this wait is taking too long.
I dont use VDJ's limiter anymore cuz I noticed when I mix 2 songs the volume turn down... If i'm playing 1 song it sounds fine. But when I play the other deck and turn up the volume fader it seems to reduce the volume. This is only when 2 songs are playing at the same time. It could happen the same if I play 3 or 4 decks... So I decided to stop using the limiter function.
Just noticed a possible bug in VDJ Pro 7.3
If you disable the crossfader in config (windows version) when you restart it doesnt remember the setting.
Works fine for me. As I use an external mixer I always disable the crossfader and the setting stays.
Just checked again changing it & exiting VDJ and it does work.
Keith
I always have the crossfader disabled too, the setting stays.
Are you using a MIDI controller that has a crossfader curve knob? If so, then this may be sending its position at start-up, causing the crossfader setting to be changed appropriately. If this is the case, you can disable it by simply deleting the mapping for the knob from CONFIG -> Mappers or change it to another function.
Settings may not save if not installed under the Administrator account.
To do this, try right clicking on the install file and select "run as Administrator"
Its a pioneer DDJ-SX installed as administrator and its definetely not saving the crossfader being disabled. Using the mapper by Phantom
The DDJ-SX has a crossfader curve knob, so as explained above, this is sending its position each time you start the software, setting the crossfader curve appropriately and also re-enabling the crossfader again as a result.
If you don't want this, either delete the crossfader curve knob mapping, or change the crossfader's mapping to video_crossfader so that it controls the video crossfader only. Please see http://www.virtualdj.com/wiki/How%20do%20I%20change%20the%20mapping%20for%20a%20button.html
Mapping the crossfader to video_crossfader is not an option with the DDJ-SX because of the way the software routes the audio for the decks. If you do that you cannot output sound from any more than 1 deck. I will look into removing it from the crossfader curve mapping and see if that cures it.
its not a major problem just a little annoying having to turn it off each time I open VDJ Pro
Can anyone help !. Since 7.3 i seem to get errors all the time when trying to download video ?. Never used to be this bad but it happens all the time now. Hope someone can give me something on this. And I know video is a bonus but it used to work well!.
There is an issue with Video netsearch at the moment in several countries. We are working on a solution. There will be a fix soon enough.
Thank you for your patience.
can we turn the sampler into a sampler? ( post-eq / fx) ?
also having to press match pitch all time?
when i sample a deck, i want WYHIWYG. the timing should be as tight as if i press the loop button. seemless and well timed.
agree?
good=)
lets do it! =)
agree?
good=)
lets do it! =)
More volume on the sampler would be good too, its always too quiet even on max.
donde lo descargo la version 7.3 pro tengo ddj ergo v
This is an English speaking forum. Please use our Spanish speaking forum, they will understand you issue better.
I'm looking to upgrade from Windows 7 to windows 8 pro, how will this affect the use of Virtual DJ Pro? Is it currently compatible with windows 8 operating system? Or should I wait?
VirtualDJ will work with Windows 8, but some hardware that you are using might not be compatible. Please check the manufacturer's websites first to ensure all hardware that you plan to use will work with Windows 8.
Also, if you don't have any problems with your existing operating system, then there's no real need to upgrade. Never upgrade just prior going to going to a gig. Make sure that you have plenty of time to be able to test and resolve any problems that you may encounter.
I'm not able to recurse using mac vdj 7.3
Is this feature disabled on mac?
The Mac version doesn't support recurse - Please see our FAQ pages: http://www.virtualdj.com/wiki/Mac%20No%20Recurse.html
Using filter folders to display the results you need is a better option and much faster (Recursing a large number of files/folders could take some to complete.)
How about effects? Will there be more effects, and can we get and Delay T3 effect like the one in Tractor?
94%
