Topic: [NEW] VirtualDJ 7.3 - Page: 5.7
Awesome!!
I don't know if I need version 8 anymore with this update! hahaha LOL
MANY Thanks to you guys!
@edmulder absolutely. I know first hand. I was bold enough to try out the new verison last night. This is the best version ever... and it will get better.
I had a problem with the 6000 when fading out of songs. At a certain point it would cut out (before this new version).
Now when I fade, it is actually a fade. The music does not cut out anymore.
Yeah sound is official!!! I decided to download it on my PC as I wait for my mac to come back and if this old XP PC can handle 7.3, I can't wait to get this on my macbook! I'll try the timecodes later and hope you guys add that color coded feature where I can label my music in the next update, unless you already did and I missed it somehow ;)
tnx
Ok Dj Koz thanks! other people with denon mc60000 and version 7.3??
I dont prefer to open a new topic. I woul like to ask which freq will you be using with new Parametric Equalizer. I was complaining that i cant kill mids completely and my aswer would be Parametric Equalizer. Btw i use ddj-ergo controller.
I have a question about the Parametric Equalizer. I am trying to duplicate my Pioneer DJM 5000. What frequency's would I need to use. I tryed look it online and had no luck. I am trying to get -26db to + 12db. Someone please help.
THANK YOU VDJ TEAM LOOKING FORWARD TO USING VDJ8
The settings only allow you to change frequency. You are trying to change the decibel range which isn't possible.
Keith
You didn't try very hard! It's in the user manual.
The frequencies are 70Hz, 1kHz and 13kHz -26/+6dB.
You can set the Hz in VDJ 7.3 but not the amount of boost/cut, or the Q (width) of the frequencies.
Keith
The cut off frequency?
OMG no stuttering in windows 8 and sound is purrrrfect ! well impressed. Hope this will be able to play 1080p without audio being out of sync soon lol keep up the good work. I like the muticoloured waveform as well and the new search feature, awesome .....
Big Thanks To VDJ Team, always working hard to bring the best.
YES! Sound and Search were two features I was looking forward to the most. THANK YOU!
Can someone fully explain the limiter,equalizer and head room volume.
Toni,
do you recommend uninstall v.7.2 and install v.7.3, or just install v.7.3 without uninstalling previous version?
Just install over the current version.
Keith
That is entirely down to your system I'm afraid - I regularly use high resolution video with no issues.
when the mapping for pioneer ddj-sx??????
28%
