The forum hasn't let me down yet so after spending the last :45 mins searching I figured I better just ask this noobish question. I need an example of how to map a button to trigger an effect that has 4 sliders. Sliders 1 and 2 are fine as they are by default but I need sliders 3 and 4 to be at 0% when I trigger the effect. I know how to map the effect itself to the preferred button but when I try to add my changes it doesn't respond. For the heck of it, I'll post what I came up with even though it doesn't work...Just to prove that I tried before I ran to the forums:)
effect "Flanged LoopOut" active slider 3 0% slider 4 0%
Please help!!
Please help!!
geposted Mon 12 Nov 12 @ 4:46 pm
Sliders will remain at the last set position. So if you use the EFFECTS page and set sliders 3 and 4 to 0%, those will be 0% next time you use them or next time you launch the software.
However if you still need to map a button and trigger the effect as long as setting those sliders to 0%, you can use this ..
effect "Flanged LoopOut" active & effect slider 3 0% & effect slider 4 0%
geposted Tue 13 Nov 12 @ 1:31 am
