hey all....
I've recently purchased Virtual DJ Pro...and am using it with the Hercules RMX 2 controller.
Right now, at my house I'm just using it with some monitors...coming out of the 3/4 RCA outputs (not the balanced outputs) on the controller.
I've noticed that I can't hear anything played on the B deck...only A deck.
Is this normal with using these outputs? I don't know if it's the controller or some type of configuration problem in Virtual DJ.
Thanks in advance for any help.
Mark
Mark
geposted Mon 19 Nov 12 @ 3:52 pm
You will need to use the 1/2 RCA outputs. When using normal master/headphones configuration, 3/4 are the same signal as your headphones. You would only normally use outputs 3/4 (In addition to 1/2) when configured for separate deck outputs to an external audio DJ mixer.
Please see http://www.virtualdj.com/wiki/RMX.html
geposted Tue 20 Nov 12 @ 5:51 am
Thanks for the response...that did it!
Mark
Mark
geposted Tue 20 Nov 12 @ 7:49 pm
