Hello!
I've just seen that i did not introduce a new tool from me :D
Well - It is a tool where you are able to copy actions from one mapping-XML to another one.
Here is the Link to the Downloadbase:
http://www.virtualdj.com/addons/15241/VDJ_Mapping_Copy_Paste.html
I made a turorial in a pdf inside the zip file.
If you have any questions please post them here to this topic.
Best regards
Best regards
geposted Fri 23 Nov 12 @ 3:13 am
i have had the chance to breeze over the functionality of this tool and its amazing.
it might not do too much, but what it does makes my life 99% simpler when mapping new gear.
thanks Chakl
three thumbs up from me.
thanks Chakl
geposted Wed 28 Nov 12 @ 2:26 pm
Hi, thanks for this awesome tool. I downloaded to check it out. However, the tutorial you are talking about that you made in pdf is not in the zipped folder. Where can i find the tutorial since I would like to use this tool but am stuck. Thanks.
geposted Tue 07 Jul 15 @ 8:05 pm
