Hi .. im quite new to all this stuff ... have twitching and shcratching noises when touch some of the faders and some of the nobs ... or sometimes when record somethin, whilst recordin all seems fine, but when listen again recorded stuff ... its faulty .. what to do??? thanks
geposted Fri 23 Nov 12 @ 1:19 pm
Check your latency setting.
Also be sure to register your copy of VDJ so you can keep up with the updates.....
geposted Fri 23 Nov 12 @ 1:55 pm
load the new drivers in the hercules. then make shure you have the asio setting with a check mark in it in the hercues settings.
geposted Tue 27 Nov 12 @ 9:42 pm
Please see http://www.virtualdj.com/wiki/Performance%20Issues.html
Also, make sure that you have the most recent VirtualDJ Console Edition v5.2.2 installed along with the latest drivers from Hercules: http://www.virtualdj.com/wiki/RMX.html
In future, please also use the correct forum when posting, which in this case would be either PC Version Technical Support or Mac Version Technical Support depending on which type of computer you have. This forum is for discussions about VirtualDJ plugins only (Effects, Video Effects, Transitions, etc.) Posting in the correct forum will ensure that your message is seen by the largest number of users who may be able to help you.
geposted Wed 28 Nov 12 @ 4:34 am
