"Your current licenses do not allow you to download Effects" why this message is displaying when i try to Download a plugin....??
Can any one help me ?? wotz the solution for dis prblm ???
geposted Wed 28 Nov 12 @ 6:57 am
Hello!
You will ned a licence here least of virtualDJ LE to download effects.
Then you are able to register your serialnumber here:
http://www.virtualdj.com/users/edit.html
But if you want to use the effects and map it on controllers, you will need in most cases the VirtualDJ Pro Full version.
See also here:
Best regards
See also here:
Best regards
geposted Wed 28 Nov 12 @ 7:01 am
will i get license for free??
Is VDJ Pro is must for using plugins??
geposted Wed 28 Nov 12 @ 8:20 am
Ämm VirtualDJ is a Payware Software - means you have to pay money to use it. Nobody can get you a licence for free ^^
Well i think some Limmited Edition are allowing you to use user effects, but i do not know which version is able to.
VirtualDJ ProFull allows everything VirtualDJ is able to do!
Please Note there is a ProBasic version also - this one allowes you also effects, but it would not be able to connect a DJ-Hardware controller.
Regards
geposted Wed 28 Nov 12 @ 8:33 am
thnkz..... :)
geposted Wed 28 Nov 12 @ 8:44 am
If you look here:
This is a site where you are able to compare all VirtualDJ versions ;)
geposted Wed 28 Nov 12 @ 8:55 am
so, i cant do anythng with ma Home Free version??
geposted Wed 28 Nov 12 @ 6:56 pm
As far as downloading skins or effects, No.
geposted Wed 28 Nov 12 @ 7:11 pm
