Has anyone tried VDJ with iTunes 11? Does the integration still work after upgrading iTunes?
geposted Thu 29 Nov 12 @ 5:35 pm
Buenas,
iTunes 11 seems to work with the latest VirtualDJ update (What is it, 7.3?). I tested playlists, and they worked. As usual, VDJ cannot play encrypted (DRM'ed) tracks.
Hope that helps.
S_S
Hope that helps.
S_S
geposted Mon 03 Dec 12 @ 3:17 am
That's exactly what I was looking for. Thanks!
geposted Mon 03 Dec 12 @ 6:58 am
OS X 10.8.2, iTunes 11.01 & VDJ 7.3, so everything up to date.
iTunes shows up in VDJ, i can see the tracks, can drag them to the left and right players, but don't get any further.... error.
Dragging files from the desktop to each of the players works fine. Music starts right away after hitting the play button.
What's up guy's?
Don't tell me to go changing someting in the iTunes folder, because iTunes works fine with traktor and serato. I'm not going to risk that smooth integration and working.
Why isn't VDJ v.7.3 integrating iTunes right out the VDJ 'box'(installer) for me?
What i notice is that my iTunes playlists in VDJ are not exactly mirroring my playlists in iTunes itself.
But they do show up fine in traktor and serato, mirroring my playlists exactly as i manage them in iTunes itself.
What are traktor and serato capable off, which VDJ is not?
regards.
What's up guy's?
regards.
geposted Mon 14 Jan 13 @ 7:31 pm
What's up guy's?
regards.
What's up guy's?
regards.
If you are using an external drive, close VDJ, eject the drive, unplug the cable and then plug it back in, lastly restart VDJ and it should and now it should see the drive. This has always worked for me. Don't know why it is doing this now.
geposted Mon 14 Jan 13 @ 8:56 pm
Sorry i just saw your post right now.
No, i'm not using an external drive. iTunes is installed on the internal drive of my MBP.
geposted Sun 20 Jan 13 @ 8:27 am
