Hi,
I hope somebody can help with a problem I am having with Virtual DJ 7 Pro. I have a Reloop Terminal Mix 4 controller and am trying to use the standard 4-deck skin (as the Terminal mix skins VU metre's are just too small). The mapping for the volume faders is set to 1-2-3-4, rather than the 3-1-2-4 configuration I want.
I have remapped the controls perfectly except for one thing, the VU metre's are still in their original configuration (so effectively are showing on the wrong fader). Is there any way to change this as I cannot use it as it is, it's just too confusing.
I guess it's something in the XML file, so does anyone have any answers for me?
I could always remap the controller to use the first two channels on the left of the controller as my main decks (to match the skin), but it seems odd that I am forced to use one side of the mixer, when the reason I bought the controller was to give me more space to mix, not less.
geposted Fri 30 Nov 12 @ 8:01 am
Can you not compare the code in the TM4 skin to the code in the normal skin?
geposted Fri 30 Nov 12 @ 11:36 am
You remapped what? The controller or the skin ?
If you want to remap the controller's VU then you find the vumeters on the mappers tab and you type:
action_deck 1 ? deck 3 get level : action_deck 2 ? deck 1 get level : action_deck 3 ? deck 2 get level : action_deck 4 ? deck 4 get level
geposted Fri 30 Nov 12 @ 11:59 am
The 4 Deck Default skin is already available with Deck mixer order 3,1,2,4
http://www.virtualdj.com/addons/12770/DN-MC6000_Enhanced_(3-1L-R2-4).html
geposted Fri 30 Nov 12 @ 8:27 pm
