Forum: Old versions
Topic: jbsystems mix 3 usb with Virtual dj 7
Myself and another dj are using the JBSYSTEMS MIX 3 USB mixer with each having a laptop.
i have 2 laptops plugged in to the jbsystems mix 3 usb mixer and i just cant get it set up so i can play music on 1 deck...and....monitor an upcoming tune on the other deck ON 1 of the laptops....i.e ( use the PFL buttons onscreen for monitoring )
i've gone through all the settings but can not set it up properly
PLEASE can someone tell me if this possible?
geposted Sat 01 Dec 12 @ 3:46 pm
The standard way would be to connect both USB cables from the mixer to one laptop, allowing you to set up each virtual deck to output directly to its own mixer channel - and then you can cue using the mixer.
If you want to use two laptops with the one mixer then the only way would be to cue using the laptop sound cards, and send the main output of each laptop to one mixer channel - but then you end up having to cue each laptop separately.
geposted Sun 02 Dec 12 @ 6:40 am
