After downloading several samples from the VDJ site I am noticing that a few are not even capable of loading into the sampler (all failed samples are in .vdj format). You go to load one and it leaves your bank blank. I tried several search queries utilizing different terms to see if anyone else has experienced this. Zilch. I checked to make sure the file actually came down (a file size more than 0 kb), re-downloaded files still nothing.
One of the troublesome samples is "Hip Hop Hooray" by roberre5 - on page 7.
Machine Specs:
Windows 7 Ultimate 32 bit.
Dell D820
6 GB RAM
250 GB WD Black Edition HDD
Latest version of VDJ installed.
System updated daily.
Virus scanner is off when mixing.
Thank you in advance for any and all help you may provide.
Machine Specs:
Dell D820
6 GB RAM
geposted Sat 01 Dec 12 @ 4:35 pm
Very odd.
I just downloaded the one you mentioned, and it won't play as a VDJ file or as a WAV (you can just rename it as a WAV) but if you save the WAV as an MP3 it loads and plays as it should.
geposted Sat 01 Dec 12 @ 5:59 pm
If someone is looking for professional samples for free. I invented something. :P
@edit
Sorry for my selfish nature, it wont happend again
here it is: [link removed]
[Moderated: Posting links to commercial sites is not permitted on the VirtualDJ forums - Please read the forum rules. Spamming the forums is also not permitted (You have posted this more than once.) DO NOT POST THIS LINK AGAIN OR YOUR ACCOUNT WILL BE LOCKED]
@edit
geposted Sun 09 Dec 12 @ 4:41 pm
