Hello,
I am looking for help with map sync button on my Mixtrack Pro controller. I was looking for answer on the forum but did not found the answer.
I would like to do something like that:
If i press sync button first time, the pitch will be set equal to second decks bpm track and LED on sync button on controller will be on. When i press sync button second time the pitch of deck will return to original bpm and LED on sync button will be off. If both tracks are playing sync button should work exacly the same way but also should sync to the beat.
Thanks for any help with that :-)
Greetings.
Greetings.
geposted Fri 07 Dec 12 @ 3:03 am
