I love using the "Square" transitions but I don't really like how Scotts is random and I don't really like the other one that blends the video in the squares.
I'd love it if I could pick which video shows up in which square. Heres a rough draft, lmmfao!!
![](/image/83495/105183/SELECT A SQUARE.jpg)
I'd like to be able to rename the .dll or whatever it is called that way I can setup multiple grids if possible.......
Thanks for looking and I hope this can be done,
Huey
Huey
geposted Sun 23 Dec 12 @ 6:30 pm
OK :)
geposted Sun 23 Dec 12 @ 8:20 pm
Let me guess, You've already got something like this in the works?
geposted Sun 23 Dec 12 @ 8:28 pm
No, but it should be an easy adaptation. I will use L/R rather than 1/2 though :)
geposted Mon 24 Dec 12 @ 10:46 am
AWESOME!!
Thank You!!
Thank You!!
geposted Mon 24 Dec 12 @ 11:35 am
Just checking in, I know your plate is pretty full.
geposted Fri 04 Jan 13 @ 2:27 pm
Must say... That would be an awesome addition ;-)
Cheers,
Roy
Cheers,
Roy
geposted Fri 04 Jan 13 @ 6:21 pm
Just a bump and seeing if anything has happened yet, lol!
geposted Tue 29 Jan 13 @ 8:57 am
Bump.............
geposted Sun 17 Feb 13 @ 12:45 pm
Just checkin if anything is in the works?
geposted Mon 11 Mar 13 @ 1:21 am
Been a while and I'd also lime to ask for a Mac version if this is in the works.
geposted Sun 09 Jun 13 @ 7:45 pm
Bump, Mac version please.
geposted Mon 26 Aug 13 @ 7:41 am
Still waiting on this to happen...........
geposted Tue 28 Apr 15 @ 6:53 am
I'd completely forgotten about this, I'll stick it back on the list.
geposted Thu 30 Apr 15 @ 8:55 am
OK, had a quick play, got this up and working. Just needs me to design a suitable GUI, then compile on the Mac and we should be good to go.
geposted Thu 30 Apr 15 @ 10:54 am
Sorry for bumpin everything, just not used to waiting, lol!!
Sounds good bro!!
I've seen what you said in the other threads, so if I had a choice on what you put out next 😜 I'd love the Quartz support before anything.
Either way as you can tell I'm still here no matter what 😜👍
Sounds good bro!!
geposted Thu 30 Apr 15 @ 11:03 am
So you know I haven't forgotten ;)
![](https://dl.dropboxusercontent.com/u/58364528/Squares.png)
geposted Tue 12 May 15 @ 10:01 am
Awesome!! 🙏
I'm gonna assume that I can set the amount of squares and also what deck goes to which square 😜
geposted Tue 12 May 15 @ 10:17 am
Well you don't set which deck goes to which square, you set the order they go in. If you set which deck goes to which square, then effectively it would be a static transition.
geposted Tue 12 May 15 @ 10:34 am
I see, perfect 👌
geposted Tue 12 May 15 @ 11:00 am
