Forum: Old versions
Topic: Library questions
I moved a folder in windows explorer and some files in virtual folders are now pointing to the wrong location. Is there a way to get virtual DJ to fix this to save me re adding tracks to the virtual folder?
Also I have som duplicate entries in the database. Exactly duplicate. 2 entries with the exact same details pointing to the exact same file. Is there a way to get virtual DJ to remove these duplicates?
Thanks
geposted Wed 02 Jan 13 @ 7:46 am
Do a check and clean on the database (which should remove any dead links) then just browse to wherever the files are now (do this in VDJ) and, providing "add automatically" is selected in the browser config, the files will get added back in at their new location.
This is all detailed in the VDJ manuals, should you care to read them!
geposted Wed 02 Jan 13 @ 1:12 pm
