I am trying to adjust the cbg in virtual dj on the skin so ripped it from another skin and adjusted the positions etc for the skin i want it to work on but keep getting errors and cant understand as have just copied it and changed the position of the button only.
</slider>
<button action="adjust_cbg" value="-32">
<size width="27" height="12"/>
<pos x="86" y="8"/>
<over x="86" y="8"/>
<down x="86" y="8"/>
</button>
<button action="adjust_cbg" value="+32">
<pos x="121" y="8"/>
<over x="121" y="8"/>
<down x="121" y="8"/>
</button>
<button action="adjust_cbg4" value="-1">
<pos x="156" y="8"/>
<over x="156" y="8"/>
<down x="156" y="8"/>
</button>
<button action="adjust_cbg4" value="+1">
<pos x="191" y="8"/>
<over x="191" y="8"/>
<down x="191" y="8"/>
</button>
If some one could help please.
</slider>
<pos x="86" y="8"/>
</button>
</button>
</button>
</button>
geposted Sun 13 Jan 13 @ 4:01 am
You keep getting errors - well what are the errors? If you don't provide relevant information, no one will be able to assist.
It would also help to state:
What skin you're using, and its screen resolution.
What skin you took the code from, and its screen resolution.
Lastly, it would probably have been better to ask in the skin area of the forum. :-)
geposted Sun 13 Jan 13 @ 5:45 am
