Forum: Old versions
Topic: Vms2 dosent load
hi evryone
the virtual dj whitch my vms2 from amarican audio came bundled with doesn't load the controller, so the controller doesn't do anything.
i have used the 20 days free pro version, but after i used that the controller and software doesn't work together anymore.
im running on a windows machine, 64bit version.
i have just installed it on another pc and it works fine on that one, and it have worked on this one aswell
do i need to delete a file, reinstall it and then it should run again?
geposted Mon 14 Jan 13 @ 11:15 am
Yes u can try that but I would get rid of the vms2 and get another controller for I have had problems with mine for months and American audio Dnt want to help much (that's just my own opinion) but yes unistall then reinstall. And if u can upgrade to vdj pro u won't regret it trust me it is greatest software ever.
geposted Wed 16 Jan 13 @ 6:22 pm
