I have a NS7 and want to leave ITCH so last night i tested VDJ, i understand it's native with NS7. Well, i don't have an original version so i downloaded from internet. The problem is that : VDJ with NS7 was a mess....audio drops, audio glitchs, etc. My question is : i haved those issues because was not a genuine version of VDJ ? Honestly, all my softwares are originals and i really want to buy a full versions of VDJ but how can i be sure after i buyit, everything will be fine ?
Thanks in advance for any advice
geposted Mon 14 Jan 13 @ 3:40 pm
Try downloading the home version, it will let you use the software for a full ten minutes unrestricted. Versions that you get out on the internet can be full of nasty stuff. You can get the genuine home version here:
http://www.virtualdj.com/download/free.html
geposted Mon 14 Jan 13 @ 9:07 pm
Thanks for your reply, i tried VDJ Home and have the same issue : when i use NS7's gain or eq knobs , software's gain or eq knobs are moving left-right , resulting audio glitches.
There are some users who experiment same issue ? Any advice are good, really want to switch from Itch....if some video will help to figure out, i'll make it.
Regards
Regards
geposted Tue 15 Jan 13 @ 2:34 am
I experience the issue, especially when played both decks.
geposted Tue 15 Jan 13 @ 3:58 am
And without NS7 , seems to be ok, no issue, VDJ works fine
geposted Tue 15 Jan 13 @ 4:32 am
The NS7 is resource hungry. What are the specs of your machine?
Keith
Keith
geposted Tue 15 Jan 13 @ 6:33 am
Macbook Pro Unibody 2008 2.4 GHz Intel Core 2 Duo 4GB Memory
geposted Tue 15 Jan 13 @ 6:14 pm
Just discover if i set in config "cd" instead "vinyl" , have no issue. But, in that way , have no longer spinnig platters, no scratch....any advice ?
geposted Wed 16 Jan 13 @ 4:48 am
Can i get some help from VDJ's staff ? How can increase-decrease NS7 driver latency ? Where i find this driver ?
Thanks in advance for any help
geposted Thu 17 Jan 13 @ 1:21 am
I really don't understand why not getting some help.....how i'm supposed to buy VDJ and can't use properly ?! Since 3 days i try VDJ Home with various settings, still have same issue : with motor on have audio glitches, sound drop and gain knobs & pitch fader moving alone , sloppy .....
Regards and thanks in advance for any advices.
geposted Fri 18 Jan 13 @ 1:51 am
You will find the latest driver on Numark Support page :-)
Please create a screenshot from VDJ Config - Soundcard and VDJ Config - Performance and isert these two here.
The we will see.
The we will see.
geposted Fri 18 Jan 13 @ 3:00 am
Haui70,
Actually i have NS7 driver, just wanted to know where is located in my laptop to make some settings in NS7 latency, not in VDJ config. I make 2 screenshots, hope that helps. I really need your help to fix my NS7......
geposted Fri 18 Jan 13 @ 12:42 pm
Any idea ?
geposted Fri 18 Jan 13 @ 10:35 pm
After i read a lots of other users posts, after almost 10 days since i ask for your help i have to say only one more thing : VDJ support it's wonderful but it's totally missing. You guys are years behind Serato's support or Numark's support.
Oh, another thing : you can do everything but NS7 will never work like a charm with VDJ like is doing with Itch.
And a message for VDJ software ...... : reast in peace !
geposted Sun 20 Jan 13 @ 2:56 am
