I purchased the controller today and it will not switch on. I think it could be the USB power supply, or the pc it is for some reason not picking up the MIDI input. I have other MIDI devices that are used on the same pc, I'm running a HP Compaq 6720s with Vista and Virtual Dj LE. Any help and suggestions would be great.
geposted Thu 17 Jan 13 @ 11:58 am
Is there any new softwere for the dixon abma3 dn virtual dj controller?
geposted Mon 01 Sep 14 @ 2:04 am
My Dixon ABMA3 won't switch on using Virtual DJ LE, is there an alternative?
geposted Sun 08 Feb 15 @ 4:40 am
I also want to know what to do? I have the same problem. Please respond URGENTLY!
geposted Fri 27 Mar 15 @ 3:06 pm
I have dixon controller abma2t ....doen show on Virtaul dj pro 7.0.5 can u hlp it a full version
geposted Sun 19 Jun 16 @ 3:11 am
I need help connecting my dixon dj controller ABMA2T to the software
geposted Mon 24 Sep 18 @ 7:04 pm
i need help with my dixon abma2t. i bought it second hand. used the serial number code and my laptop crashed a while after. i had lost my serial code and now it will not work? is there anyway i can get it to work again?
geposted Thu 17 Jan 19 @ 7:50 pm
You cannot use someone elses serial number.
The previous owner of your controller would presumably have registered Virtual DJ himself, and used the serial number. He cannot legally transfer the serial number to you if he's used it already, and you cannot legally use it.
You need to buy your own license.
geposted Thu 17 Jan 19 @ 8:08 pm
my amba3 does not have output when connected to virtual dj .... only headphone works ... what cud be the problem?
geposted Wed 16 Oct 19 @ 4:53 pm
