Forum: Old versions
Topic: Hercules RMX2 keypad delay
Hey guys i've been following these forums for a while and have gotten lots of valuable information but after searching pages and pages I could not find a topic that applies to the issue that im having.
As you can see i had/still have the original RMX and after getting the RMX2, I noticed that there is a delay in the CUE mode when you press the keypad... Is this a known issue and I just have to get used to different (much different) timing or am i not configuring something right?
Please help here or direct me to a thread that this topic was discussed before.
THank you
geposted Fri 18 Jan 13 @ 1:55 am
Any chance you have the Smart Cue enabled ?
In the Default 2 Decks skin its a small locker icon next to the HotCue buttons. It should be off (grey)
geposted Fri 18 Jan 13 @ 6:00 am
Yea the key lock is always off... :(
geposted Fri 18 Jan 13 @ 12:41 pm
Can you be a bit more specific about the problem?
Are you saying there's a delay between you pressing the cue button and cue engaging, or are you saying the cue audio is delayed compared to the main output?
geposted Fri 18 Jan 13 @ 5:29 pm
There is a major delay between pressing the pad in cue mode and cue actually engaging. This was not the case with the first RMX controller.
geposted Fri 18 Jan 13 @ 5:40 pm
does it only fire when you release the button?
Good point, will check when i get home in an hour...
geposted Fri 18 Jan 13 @ 5:57 pm
it actually fires when u press it not when it releases i just checked.
geposted Fri 18 Jan 13 @ 7:33 pm
For anyone else that is having this issue there is a very simple fix for it..
Just check the ultra latency ASIO in the Sound Setup tab..
Thanks for everyone's help anyway. :)
geposted Sat 19 Jan 13 @ 4:19 am
