Hello guys, I am using full version of Virtual DJ pro 7, my controller is Numark Mixtrack Pro, when I mix songs as soon as I press effect button on my controller Virtual DJ shuts down :( I tried to do everything but there is no result, i can't play more than 10 minutes, sometimes it shuts down even without pressing effect buttons. what should i do?
geposted Fri 18 Jan 13 @ 5:40 pm
Register your Pro Full serial number to your Profile Page (under LICENSES) http://www.virtualdj.com/users/edit.html
and follow instructions here for a clean installation.. http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
Backup all the dll files in your VirtualDJ\Plugins\SoundEffects folder (leave the folder) empty.
Place the dll files one by one in the above folder and launch VirtualDJ each time after that.
Probably one of those plugins may cause the issue.
If you run Windows, it is advised to install the below..
x86 (32 bit): http://www.microsoft.com/downloads/details.aspx?FamilyID=a7b7a05e-6de6-4d3a-a423-37bf0912db84&displayLang=en
or
x64 (64 bit): http://www.microsoft.com/downloads/details.aspx?FamilyID=bd512d9e-43c8-4655-81bf-9350143d5867&displayLang=en
depending on your OS and DirectX9 from here.. http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2da43d38-db71-4c1b-bc6a-9b6652cd92a3&displaylang=en
or
geposted Fri 18 Jan 13 @ 9:01 pm
I am using macbook. i lost my serial number, how can i find it?
geposted Sat 19 Jan 13 @ 9:11 am
If you purchased Virtual DJ from this site, please send a support ticket detailing the email address you bought it against and Support will contact you.
Regards
Keith
Regards
Keith
geposted Sat 19 Jan 13 @ 9:15 am
SOY DE VENEZUELA . COMPRE UN CONTROLADOR NURMAK MIXTRA, QUE VIENE CON UN CD DE VITUAL DJ , PERO SOLO DURA 10 MINUTO , LE METO EL SERIA Y SALE INCORRETO
geposted Fri 22 Feb 13 @ 8:53 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
geposted Fri 22 Feb 13 @ 10:29 am
