Forum: Old versions
Topic: Versadeck - can't find mapping
KrotarHome userMember since 2013
Hello,
I have a versadeck (http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1458).
With it I received a CD with virtual DJ LE on.
I installed this and after 20 days my trial has expired. When using virtual DJ LE it knew my device and it configured the mapping automatically.
Now I upgraded to Virtual DJ pro but all the mapping is lost. I can't seem to find it.
I have installed the virtual DJ LE on a second pc to get the mapping back but the mapping is not found in /users/name/documents/virtualdj/mappers. The folder is just empty (so I can't copy any mapping to the pro version).
How does this come? Is there a possibility I can copy the mapping for my versadeck from the LE to the PRO because setting up each key manually will take me 3 to 4 hours...
Regards,
Krotar
geposted Sun 27 Jan 13 @ 4:33 am
This is probably because you are using an out-of-date version of VirtualDJ Pro that doesn't support the Versadeck.
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
Your VirtualDJ LE serial number should entitle you to a discount off the cost of purchasing.
geposted Sun 27 Jan 13 @ 11:39 am
