Hello all, been a while since I posted here. I have vdj and hurcules RMX with all recent updates and drivers. My problem is after playing for a bit the sound will suddenly get crunchy (no better way to describe it) or static like and will stay that way until i close down the program, unplug the controler and then restart it. any clue what it is? i thought it might be the usb cord but i haven't moved it so im lost right now. any help?
geposted Thu 31 Jan 13 @ 5:35 pm
Have you tried the stuff in the FAQ for PC performance?
http://www.virtualdj.com/wiki/Performance%20Issues.html
geposted Thu 31 Jan 13 @ 6:11 pm
Yes i have a toshiba satelite L655 and its completely stripped down and is used only for djing. Im uninstalling and reinstalling the drivers.
geposted Thu 31 Jan 13 @ 7:51 pm
Your computer may not be supplying enough power to the RMX.
First, try disabling power management for it in Windows Device Manager.
If this doesn't help, try plugging it into a mains powered USB hub.
You could also try using a dual power USB cable (This uses two ports to provide more power to the device.)
geposted Fri 01 Feb 13 @ 5:49 am
well after all the updates and reinstalling everything, it began to sound static like after 20 min of playing. but then i did what you said and disabled it and it fixed it. lets hope it stays! thank you
geposted Fri 01 Feb 13 @ 8:14 am
You may want to look into modifying the ASIO buffer size, which might not be adequate:
http://ts.hercules.com/faqs/eng/her_eng_00445.pdf
geposted Fri 01 Feb 13 @ 12:54 pm
