Hi I have js changed laptops and I now cant see my iTunes playlists on virtual dj can anyway please help?
geposted Thu 07 Feb 13 @ 10:56 am
geposted Thu 07 Feb 13 @ 11:24 am
Having Trouble, Please help!
#1 How do you? Make a backup of the file iTunes Library.itl (stored on the home folder of iTunes).
#2 Ensure that iTunes is closed, then rename the file ITunes Library.itl to iTunes Music Library.itl
#3 Now it's the time to select the correct database: If you are using Windows, hold down the SHIFT key and open iTunes. Then click on "Choose Library" and select the file: iTunes Music Library.itl
#4 Close iTunes. The file "iTunes Music Library.xml" will be generated automatically and VirtualDJ will recognize the playlist
#5 Where is the folder Registry tool? If not, use the Registry Tool and check that the home folder of iTunes is correct, as shown in the image below.
geposted Mon 11 Feb 13 @ 5:30 pm
