I have it all setup and not everything works can someone tell me y
geposted Sun 10 Feb 13 @ 10:53 am
You need to give more information than that!
Keith
Keith
geposted Sun 10 Feb 13 @ 12:17 pm
Did you set the SX into Normal Midi Mode?
geposted Sun 10 Feb 13 @ 1:23 pm
the needle strip and the jog wheel light in the middle does not work it ether is on or off it wont follow the music
geposted Sun 10 Feb 13 @ 3:38 pm
You must switch your unit to "Other than Serato DJ" mode.
Please refer to your DDJ-SX manual in order to do so.
Then it should work!
geposted Mon 11 Feb 13 @ 12:33 am
When I look in the book I can't find where it tells me how to set it up for other software
geposted Mon 11 Feb 13 @ 8:01 am
It will only scratch when the fader is on the none playing side so when I move it to hear it through the main pa it just lets me pitch
geposted Mon 11 Feb 13 @ 8:08 am
First of all reset the mapper back to it's factory defaults.
Second, look at page 26 of your DDJ-SX manual.
geposted Mon 11 Feb 13 @ 10:41 am
I don't have one it was a free gift from my boss he does not have it so I am stuck
geposted Mon 11 Feb 13 @ 10:53 am
Google to the rescue: http://pioneerdj.com/support/files/img/DRI1094B.pdf
Keith
Keith
geposted Mon 11 Feb 13 @ 10:58 am
Actually why don't you just download the manual?
http://pioneerdj.com/support/product.php?lang=en&p=DDJ-SX&t=man
And then you select your language!!!
geposted Mon 11 Feb 13 @ 11:15 am
Thanks I will try it out
geposted Mon 11 Feb 13 @ 1:33 pm
OK it will let me scratch for a few seconds then it starts to sound line a bend
geposted Mon 11 Feb 13 @ 3:58 pm
Everything is working great thanks for everyone's help
geposted Tue 12 Feb 13 @ 6:00 am
