Just got a new laptop with windows 8 and for some strange reason i cant use timecode with my numark n4. In order to use timecode with my n4 i need to use asio4all, but when i select asio4all i cant use my n4 as a soundcard and virtual dj wont react to anything im doing on my n4. can anyone help me please ? thanx
geposted Tue 26 Feb 13 @ 10:00 pm
You shouldn't need ASIO4ALL, because the N4 has a class compliant audio interface - meaning it works with the standard windows WDM sound and doesn't require a its own driver.
ASIO4ALL is not an ASIO driver anyway, it's just an emulator that sits on top of the normal Windows WDM driver. Its purpose is to fool "ASIO only" software (which is very rare these days) into working without an ASIO card, and as such is not required, because VDJ works without needing ASIO.
geposted Wed 27 Feb 13 @ 2:42 am
In order to use my timecodes i need the asio4all. (when i put timecode input, the only soundcard i can choose is asio)
geposted Wed 27 Feb 13 @ 6:06 pm
if you can please help me with the issue it'll b koo,thanx
geposted Wed 27 Feb 13 @ 6:08 pm
No you don't - as I already explained.
You don't have an ASIO card. Your controller doesn't have an ASIO compatible audio interface. The ASIO4ALL driver is not an ASIO driver.
Uninstall the ASIO4ALL driver and use the advanced config to set up the inputs and outputs.
You'll also need to make sure the N4 is set up correctly (switches in the right place etc.).
geposted Thu 28 Feb 13 @ 9:38 am
You can not setup Timecodes without using WDM Drivers for a soundcard. The driver must be an ASIO-based driver.
The user's attempt is correct for the Numark N4. ASIO4ALL is required. http://www.numark.com/product/n4
Seems there is an updated version of ASIO4ALL that is 'beta' that works with Windows 8.
Please see this discussion about ASIO4ALL and Windows 8 from the Numark forum -
http://community.numark.com/numark/topics/does_the_asio4all_driver_work_with_windows_8
geposted Thu 28 Feb 13 @ 10:20 am
Assuming you've worded that wrongly, if it's not possible with WDM then why does advanced config give me the option of using my primary sound card as a timecode input?
The website actually says that it's optional - and so does the Numark employee in the thread you linked to.
Ventura, you need to give us more detail of exactly what settings you're using, and so on. If you've followed the Numark instructions it should work.
geposted Thu 28 Feb 13 @ 10:50 am
@cstoll did the update but still not working. @groovin I tried In advance config still dosnt work. The problem is that in asio mode i can only use my laptop soundcard and not my n4, i need to use my n4 soundcard to play my timeccode
geposted Thu 28 Feb 13 @ 6:43 pm
so no one can help me with this issue?
geposted Sun 03 Mar 13 @ 12:00 am
As the N4 is a Numark product, have you tried looking/asking on the Numark support site?
geposted Sun 03 Mar 13 @ 4:55 am
@groovindj i have and i still havnt got a response.
geposted Sun 03 Mar 13 @ 12:29 pm
can any teamer help me with this issue please? Thanx
geposted Fri 08 Mar 13 @ 6:12 pm
@pochitodj thanx but thats the problem. If i check the n4 soundcard it wont let me play my n4
geposted Sat 09 Mar 13 @ 11:11 pm
Now delete asio4all drivers, clean the registry keys.
And download and installed asio4all to www.asio4all.com
On your operating sistem. Controlling the compatibility with your sistem
Sorry for my English.
geposted Sun 10 Mar 13 @ 10:44 am
