i am setting my setup on my new pc here is what i have 2cdj 2000 and djm 400 connected 2 vdj but i only have sound comming out of the left speaker ? i was thinking it was a vdj setting problem . cause i have not changed anything else just my pc.
Here is how the sound settings look like
input is none
output external mixer
soundcard - asio driver - pioneer cdj asio driver
input is none
geposted Sat 02 Mar 13 @ 10:46 am
I found out it was not a software problem cause i tried using cds anyone have any ideas
geposted Sat 02 Mar 13 @ 1:44 pm
Take a look at the meters on your mixer.
If only the left channel is showing a signal, then the problem is before the mixer (or is the mixer itself). If both channels are lighting, then the problem is after the mixer. If it's only playing on one side no matter which CDJ you use, it's not likely to be the CDJs or the cables from the CDJs.
geposted Sat 02 Mar 13 @ 5:19 pm
