Hi there.
My setup is 1 djm 2000 mk1 & 2 cdj 2000 mk1.
Using them with HID/Midi.
I have problem with my djm 2000, it seems like the channels is mixed up with the EQs, it controls the other channel of the mixer on my PC.
When I try to setup my own config I cant separate the left/right channel ?
Have tried to change all different configs, and have nothing left to try ?
One more thing I would like to have some help with is to config the preelisten on the djm 2000 aswell ?
Thanks in advance,
Fredrik
Thanks in advance,
Fredrik
geposted Sun 10 Mar 13 @ 1:07 am
You're trying to control the VDJ mixer with the DJM?
Why? There's no need to use the "pretend" mixer on screen - you have a real one!
What you should be doing is setting VDJ to 'external mixer' and setting the output from each VDJ deck to a separate CDJ-2000.
Connect the outputs of the CDJs to the DJM mixer and mix on that. The DJM headphone cue will work as normal.
geposted Sun 10 Mar 13 @ 8:03 am
Thats what I do when I do gigs live, but want the opportunity to controll things when I might be on the VDJ Radio.
Dont need to buy me a cheap midicontroller for that...right ?
geposted Sun 10 Mar 13 @ 1:11 pm
Are you using one of the DJM-2000 mappings from here?
geposted Sun 10 Mar 13 @ 2:37 pm
I did load this one: http://www.virtualdj.com/addons/15671/DJM-2000_Nexus___2000.html
geposted Mon 11 Mar 13 @ 12:09 am
I might do my own mapping instead, but how do I separate the channels with Eqs (what do i wright in config) ?
For example: now I only find "eq_low, eq_mid and eq_high" in config. for both channels, how do i separate them for each channel.
geposted Mon 11 Mar 13 @ 12:16 am
I would suggest that you try the other mapper first, to see if it works better.
Then if you want to do your own mapping, it would probably be better to ask in the skins forum (or maybe the plugins forum).
geposted Mon 11 Mar 13 @ 10:10 am
i can't even get my EQ's to work with virtual dj? can you guide me to correct this?
geposted Wed 24 Apr 13 @ 8:45 am
You shouldn't do this because as explained in your other similar post regarding the volume sliders, it's a real hardware mixer and has hardware EQ's.
Please see the response in your other topic http://www.virtualdj.com/forums/136312/PC_Version_Technical_Support/How_to_connect_two_CDJ2000_with_Virtual_DJ_7__.html for further information.
geposted Wed 24 Apr 13 @ 10:43 am
