If this has already been asked, then Im sorry as my search did not return an answer for me.
I am upgrading my equipment this year. Including a new Macbook pro YAY!
I want to go with virtual dj pro for the Video options, and effects that are non existent on other systems. I also would like to use the time code features that are available.
I have been using serato with the sl2 and one 850 cdj via the input reverse option
1. I would like to continue using my single cdj setup, BUT is there an option/set up in VDJ pro that would allow this WITH video mixing?
2. Would I have control over the video's crossfader from my mixer? If not... what set up would be needed to achieve this?
***Scratching is a must so please do not suggest a controller, IF it does not have realistic scratching capabilities***
Im looking at the American Audio DV2 USB mixer because its crossfader does send a midi signal.
http://www.adjaudio.com/ProductDetails.aspx?ItemNumber=1468
Its important that any setup/solution involves video mixing, because that is the single reason that I am going with VDJ pro.
geposted Sun 10 Mar 13 @ 5:58 pm
When using a single CDJ-850 as a HID controller with VirtualDJ, you can simply press the EJECT button to toggle it between the 2 decks (Or all 4 decks if you are using a 4 deck skin.)
The DV2 is a MIDI capable mixer, so all you need to do is map its crossfader to video_crossfader to allow you to control the video crossfader in VirtualDJ. Please see http://www.virtualdj.com/wiki/How%20do%20I%20map%20my%20MIDI%20controller.html
NOTE: When using a real hardware mixer, you should not map the EQ knobs, volume, etc. Just map the crossfader only for video crossfading. Please see http://www.virtualdj.com/wiki/MIDI%20mapping%20an%20external%20DJ%20mixer.html
geposted Mon 11 Mar 13 @ 6:48 am
Thank You!
geposted Mon 18 Mar 13 @ 3:51 pm
