Forum: Old versions
Topic: headphone trouble
Please please, I have just started and have very little knowledge, so could please someone help, most def the easiest thing to do. So basically I have had my Mac plugged into my mixer through an audio interface, but I haven't worked out how to connect my headphones up correctly to use when mixing, I know it's in the config settings but I don't know how, sorry for the dumb question but please please help. i also understand that you will most prob need more details to determine what I need to do, so please just ask.
thankyou charlie
geposted Tue 12 Mar 13 @ 11:38 am
Haui70PRO InfinitySenior staffMember since 2008
Hi Charlie
it would help to understand your setup and what VDJ version you use.
Soundcard, external mixer, midi controller etc.
geposted Tue 12 Mar 13 @ 11:43 am
and before someone says read the guide etc i have tried this, i just get both channels playing on the headphones etc or just one
geposted Tue 12 Mar 13 @ 11:44 am
ok, well its my dads old mixer, it says on it, CITRONIC CDMIO.4DSP
audio interface is a BEHRINGER U-CONTROL UCA222
VIRTUAL DJ 7.03 PRO
THANSK FOR THE FAST REPLY
geposted Tue 12 Mar 13 @ 11:47 am
The soundcard is the problem, because it does not have enough stereo outputs.
While using this soundcard you just can use it the following way.
Input - none
Output - Headphone
Soundcard - 4-out ---_> beside select the soundcard
Connectthe soundcard with your headphones and the soundcard output with your speakers.
geposted Tue 12 Mar 13 @ 11:54 am
ok i did that, but im obviously doing something wrong, the sound is coming out of both the headphones, and the speakers at the same time? sorry for my complete stupidity
geposted Tue 12 Mar 13 @ 12:00 pm
is what you refer to as the sound card, is that the audio interfce ?
geposted Tue 12 Mar 13 @ 12:19 pm
thanks fir yiur help mate, its just so confusing lol
and even more frustrating
geposted Tue 12 Mar 13 @ 12:38 pm
Please see http://www.virtualdj.com/wiki/External%20mixer%20pre-listening%20with%20headphones.html
The Behringer UCA222 only has a single stereo output so is unsuitable for separate deck outputs to an external mixer. You will ideally need a proper dedicated multi-channel DJ sound card such as Numark DJIO. Or you could use two UCA222's (One for each deck.)
Please also register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
NOTE: If you aren't using MIDI controllers and don't need full-screen video, then VirtualDJ Basic also supports separate deck outputs to an external mixer: http://www.virtualdj.com/products/basic.html
geposted Tue 12 Mar 13 @ 12:53 pm
