In Virtual DJ Pro I can't find the button to set the master tempo. In Virtual DJ LE it used to sit just next to the BPM number. How do I set one disc as the master tempo?
Also, after fiddling with my settings, my BPMs are now stuck on both decks and I can't figure out how to unstick them.
Any help on this would be much appreciated.
geposted Wed 13 Mar 13 @ 9:09 am
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.) Your VirtualDJ LE serial number should entitle you to a discount off the cost of upgrading (Unless it's second hand and has already been used.)
On the default VirtualDJ v7 skin, key lock (master tempo) can be turned on/off by clicking the padlock icon next to the pitch slider. Please read the user manual for further information: http://www.virtualdj.com/wiki/PDFManuals.html
geposted Wed 13 Mar 13 @ 9:11 am
