Can anyone help. I've switched from being a Windows user with VDJ and was able to drag & drop tracks into the Automix Playlist panel, especially when someone has reqyested a track, so that I could then play it at a suitable time. However, when I try to do this with my Mac Pro the tracks disappear when I click on another folder to select further tracks. This feature was very handy for requests, but is now totally redundant??????
Cheers
Ken.
Cheers
Ken.
geposted Wed 13 Mar 13 @ 3:01 pm
Please change at VDJ Config - Option the way the folder should act.
[AutoLoad Playlist]
Disabled – a contents of the play list are displayed in the center File Browser panel only
Always – when a play list is selected in the browser the contents are immediately loaded to the playlist
Smart – doesn't change the playlist when you click on a playlist folder, if the actual playlist has been manually edited
Guess you have used on PC system the option SMART :-)
[AutoLoad Playlist]
geposted Thu 14 Mar 13 @ 2:53 am
Many thanks Hau170, Smart did the job. ;o)
geposted Thu 14 Mar 13 @ 1:59 pm
