please, i have bought a pioner ergo v and install this software (vdj LE) in a macbook pro, but i try to record a mix i can't record in mp3, only can in wav, the problem is that .wav is bigger than mp3, how can record in mp3? i not see the buton "config" over the start record...
geposted Sun 17 Mar 13 @ 8:23 am
in the limited edition the record it's limited. Try the free version. if it works, unfortunately you have to buy the pro version (because you can not use the free controller.)
http://www.virtualdj.com/download/free.html
geposted Sun 17 Mar 13 @ 10:34 am
