i cant download skins because am not licence registered,what must i do to be registered for licence
geposted Fri 20 Sep 13 @ 7:40 am
Please read our FAQ pages:
http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
geposted Fri 20 Sep 13 @ 7:54 am
Do i have to download a "slip mode" effect in order to work the slip function?
geposted Tue 24 Sep 13 @ 12:25 pm
no, it's integrate in the last Virtual DJ 7.4 pro version
geposted Tue 24 Sep 13 @ 10:11 pm
how to download
geposted Fri 25 Oct 13 @ 9:45 am
As above, please read our FAQ pages:
geposted Fri 25 Oct 13 @ 10:16 am
Very nice skin!
geposted Thu 07 Nov 13 @ 4:31 pm
Thanks !!
geposted Fri 08 Nov 13 @ 5:48 am
how can we register as a license user?
geposted Tue 31 Dec 13 @ 6:52 am
www.virtualdj.com/buy/index.html
geposted Tue 31 Dec 13 @ 7:31 am
hello guys
I really need skin pioneer CDJ2000 NEXUS but um not able to download them what should i do
geposted Tue 25 Mar 14 @ 10:36 am
You will need to purchase VirtualDJ and register your serial number to be able to download custom skins.
If you like VirtualDJ, then please support the software and its future development by purchasing it.
geposted Tue 25 Mar 14 @ 10:58 am
hi i dont see de pad buttens on the right of my screen when i select the rmx skin
![](/image/26562/137241/vdj probleem.jpg)
do you have any idee/ tips?
And why can i set the effects butten on the master why only on ch 1 or ch2 of ch3 or ch4 ?
greetz arnaud from NL
geposted Tue 27 May 14 @ 8:50 am
ther is 2 versions of this skin, with or without RMX pad :
http://fr.virtualdj.com/addons/15766/Pioneer_CDJ2000_DJM900_NEXUS.html
http://fr.virtualdj.com/addons/15876/PIONEER_CDJ2000_DJM900_NEXUS___RMX.html
did you have the good version ?
geposted Tue 27 May 14 @ 3:51 pm
i have insall the 2 versions and i start up just a view minuts ago to check it and when i select de rmx version i dond get the pads see first image
![](/image/48523/137362/vdj probleem.jpg)
en now when i select witout vdj says :
![](/image/81840/137363/vdj probleem 2.jpg)
Yesterday I could the skin (cdj200 and djm900 without RMX) do use
i think this image is beter
![](/image/80146/137361/vdj probleem 3.jpg)
gr arnaud
gr arnaud
geposted Wed 28 May 14 @ 3:24 am
with english text
![](/image/41194/137365/vdj probleem 3.jpg)
greetz arnaud
greetz arnaud
geposted Wed 28 May 14 @ 3:33 am
there I do not know what happens ! Never heard of such problems...
What version of VDJ did you have ?
geposted Wed 28 May 14 @ 7:23 am
hi i have vdj 7
I have also been the software and everything (skins maps and stuff) removed and then reinstalled, unfortunately without results.
geposted Wed 28 May 14 @ 7:42 am
maybe you have an older version of the skin. Have you downloaded the latest ? Because it was often been corrected.
geposted Wed 28 May 14 @ 9:58 am
i downloaded the skin this week..
arnaud
arnaud
geposted Wed 28 May 14 @ 11:28 am
