So I upgraded to the new Ver. 7.4 which should have native support for the DDJ-SX. However, mine is not working properly. Only thing responding are: Track Select, Load, Cue and Play functions. All other functions are not responding. Mixer has no responses at all. Matter of fact when decks A and B are playing, even with the up faders down to 0, both decks can be heard coming out of Master.
I never had the previous mapper made for the DDJ SX. I was using Serato DJ until VDJ can support it natively. So there is no old mapper to delete. Have the unit set to use Serato.
VDJ Config:
INPUT: None
OUTPUTS: Headphone
SOUNDCARD: 4 - Pioneer DDJ-SX
I am running a Macbook Pro on Mountain Lion.
VDJ Config:
INPUT: None
OUTPUTS: Headphone
geposted Sun 24 Mar 13 @ 5:09 pm
BTW, meant to type 7.4 in the title not 7.5 hahahah
geposted Sun 24 Mar 13 @ 5:12 pm
did you upgrade firmware to ver. 1.05?
geposted Sun 24 Mar 13 @ 5:44 pm
I have changed the title to reflect this.
Keith
geposted Sun 24 Mar 13 @ 5:49 pm
try to use 4 deck skin
geposted Sun 24 Mar 13 @ 5:52 pm
Yes I have
Saw that from the other thread, and tried it. Mixer section is still NOT responding/functioning.....
geposted Sun 24 Mar 13 @ 10:34 pm
Check that the INPUT SELECT switches on the front are all set to PC.
Choose the default VirtualDJ v7 4 deck skin and then restart the software.
NOTE: You can use other sources on CH3 & 4 if you wish, but to do this, you will need to use a 4 deck skin for now. This is because when using 2 decks, decks 3 & 4 of the controller wrap back around to 1 & 2, so the input select switch settings for these decks confuse the software. This will be fixed in the next update. You can also work around it when using 2 decks by switching the inputs of CH1 & CH2 to PHONO and back to PC again, but you would need to do this each time you start the software.
geposted Mon 25 Mar 13 @ 12:55 pm
Switching it all to PC and running a 4 deck skin seem to do the trick. Thank you very much!!!
One thing I noticed though is that my CPU usage when playing video is now around 70-80%. Really high....
geposted Mon 25 Mar 13 @ 9:09 pm
It's unlikely that this is related to using the DDJ-SX - Using MIDI controllers has very little CPU overhead, even for complex controllers.
Most likely this is because you have resized or maximised a skin that's not optimal for your computer's screen resolution or there is some other performance or configuration issue with your computer.
Please see:
https://virtualdj.com/wiki/Performance%20Issues.html
https://virtualdj.com/wiki/My%20video%20output%20runs%20slowly%20or%20is%20very%20choppy.html
Please see:
geposted Tue 26 Mar 13 @ 8:42 am
This may be the problem then since I changed to a different skin (4deck) to use. I'll check that out. Thx.
geposted Wed 27 Mar 13 @ 8:23 am
How do I download this? I don't know which level. Plus I am new to Virtual Dj. I want to download the skin on a Macbook Air. What should I do?
geposted Wed 27 Mar 13 @ 10:16 am
You will need to purchase the full VirtualDJ Professional to be able to use MIDI controllers such as the DDJ-SX, custom skins and other add-ons: https://virtualdj.com/buy/
If you have already purchased VirtualDJ, please register your serial number to your account https://virtualdj.com/users/edit.html and then download the latest v7.4 version from your download center: https://virtualdj.com/download/updates.html (VirtualDJ v7.4 has native support for the DDJ-SX.)
If you haven't purchased VirtualDJ, then please support the software and its future development (Especially if you are a working DJ and you are making money as a result of using it.)
geposted Wed 27 Mar 13 @ 11:52 am
Have upgraded the firmware. Downloaded the mapper. Have it set to serato mode. The front switches are set to pc mode. Jog wheel not working. Play button not working. Any help?
geposted Fri 05 Apr 13 @ 11:06 am
Do NOT use the download mapper while using the SX in SERATO mode!
Delete the SX mapper XML from the MAPPER folder inside the VirtualDJ folder and also the SX XML from the device folder!
NO NEED TO USE THE MAPPER FROM THE DOWNLOAD AREA IF YOU LIKE TO USE THE SX IN SERATO MODE!
This should slove the problem ;-)
NOTE:Please use only the download mapper only, if you have the SX in OTHER mode!
If you want to switch from other mode to serato mode, delete the dmapper and the device xml!
geposted Fri 05 Apr 13 @ 2:57 pm
just to just to clarify: if i want to use PhantomDeejay's mapper, i Download mapper and save it to Documents\VirtualDJ\Mappers
do i have to have anyting in : Documents\VirtualDJ\Devices ?
and i have 7.4 install and ddj-sx switched to serato mode..
thank you!
thank you!
geposted Mon 29 Apr 13 @ 6:35 pm
m having a issue tht my sound keep breaking up and if i load the song on deck 2 or any deck it gets messed up only the sound everythng else is working fine. m using vdj7.4pro with ddj sx. your answer will b helpful thanks
geposted Fri 31 Jan 14 @ 11:50 pm
Please ensure that your computer has been optimised for DJ performance:
geposted Sat 01 Feb 14 @ 3:59 pm
Hi good afternoon, I just got the pionner DDJ SX and Im using the virtual DJ 7.4, where can i get the mapper?
Thanks
Carlos
Thanks
Carlos
geposted Mon 23 Mar 15 @ 7:17 pm
