I have a laptop running on XP that i just reinstalled. I download Virtual DJ Home to give it a try, but the install fails with this message:
"Virtual DJ Home FREE Setup Wizard ended prematurely because of an error. Your system has not been modified. To install this program at a later time, run Setup Wizard again. Click the finish button to exit the Setup Wizard."
My laptop works fine, everything has just been reinstalled, including all the drivers ! Where can I start ? This message gives no clue...
thanks in advance
thanks in advance
geposted Wed 27 Mar 13 @ 11:23 am
make sure you don't install directly off a network share or a read-only media. Download/Copy the installer to your desktop and try again.
geposted Wed 27 Mar 13 @ 12:14 pm
The installer was in the downloaded files folder, so not a read-only media. But thanks
geposted Wed 27 Mar 13 @ 12:22 pm
Make sure that you have Windows XP Service Pack 3 installed along with all other updates.
Also, try performing a clean re-installation of VirtualDJ Home FREE: http://www.virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
geposted Wed 27 Mar 13 @ 1:26 pm
I did as you said, and installed the Service Pack 3, and all Windows updates... but still impossible to install Virtual DJ
I don't have a clean reinstall to do, as the computer has just been reinstalled, including a system disk format
Thanks anyway
Thanks anyway
geposted Wed 27 Mar 13 @ 3:42 pm
humm, disable your antivirus/antispyware software?
geposted Wed 27 Mar 13 @ 6:05 pm
I have no firewall nor antivirus installed. I kinda solved my problem as I found a 7.3 Home Edition on the web and could install it...
geposted Thu 28 Mar 13 @ 6:16 am
There is no such thing as v7.3 Home Edition. Home Edition was discontinued some time ago when VirtualDJ Home FREE was launched.
The version that you have found is probably an illegal cracked version of the software and could contain viruses, spyware, etc.
Please remove this illegal version immediately, then contact support for direct assistance with installing the latest legitimate VirtualDJ Home FREE: http://www.virtualdj.com/contact/index.html
If you like VirtualDJ, please also consider supporting the software and its future development by purchasing it: http://www.virtualdj.com/products/comparison.html
geposted Thu 28 Mar 13 @ 7:19 am
I meant Virtual DJ version 7.3 Home FREE (b422)
geposted Thu 28 Mar 13 @ 7:39 am
Virtual Dj Home Free Setup Wizard ended Prematurely because of an error. Your system has not been modified. To install this program at a later time, run setup wizard again.
what should i do now?
geposted Fri 10 May 13 @ 11:18 am
