Hi,
This is my wish list for Version 8.
No doubt I reckon some are already in the works or have been suggestested already.
In any case if there is an easy way of achieving any of the suugestions below using the current V7 version then please let know.
Most of a proper tuturiol on all the various functions and possiblities will be most welcome
Thanks
Suggestions for V8
PlayList
1. Playlist name displayed on top of Playlist window + a save button (which will save any edits to the same filename)
2. Together with total length of songs.
Also total Number of Songs, and an active how many played / yet to play totals
3. Ability to set play time before auto mix. e.g 90, 120, 150 & 180 seconds
Automix will then kick in at the best mix point around the time
(many modern genres now require very short playtime)
4. Display Name of next song queued to be played just underneath the wave length window. This will particularly be useful when in random play
Decks
1. A 'Mix Now' Button which will do a smooth slide of the crossfader from active deck to the opposite deck
This can further be configured under 'Options' e.g: Slide speed, Cross fade time, equaliser mix etc.
2. A 'Jump In' button which will cut the playing song on the active deck and start song on the opposite deck without losing beat (a bit like what is done in 'smart' under automix when using playlist)
3. Place asterisk on loaded songs with strong beats (e.g. *120) just like what we get on 'Mix Tempo allowed' playlist songs. This will enable a decision on whether to 'Mix Now' or 'Jump in' option
4. Hovering mouse at any point on the wave should display track time for that point in a tool tip format
5. 3 or 4 customisable buttons that can be programmed using VDJScripting
Search
1. Search should list results first from the database and then from 'Playlists' (perhaps in a different colour)
Thanks
Suggestions for V8
PlayList
Decks
Search
geposted Sun 07 Apr 13 @ 9:51 am
