Forum: Old versions
Topic: can't search by bpm
under 'search' i've selected 'search in folder' & 'bpm' if i type any bpm number i have in the folder, nothing shows up.
geposted Fri 12 Apr 13 @ 9:16 am
You need to enter a range, for example 122-123 for the search to work.
Keith
hmmm still dont see anything even though i have bpm and tracks informatioin
Make sure you set it up first by useing the magnafyer near the search bar,
click it to set up how to serach.
nm got it figure out, needed "Search in drives"
edit
seems "search in folder" doesn't work as it says
