under 'search' i've selected 'search in folder' & 'bpm' if i type any bpm number i have in the folder, nothing shows up.
geposted Fri 12 Apr 13 @ 9:16 am
You need to enter a range, for example 122-123 for the search to work.
Keith
Keith
geposted Fri 12 Apr 13 @ 10:06 am
hmmm still dont see anything even though i have bpm and tracks informatioin
geposted Fri 12 Apr 13 @ 9:36 pm
Make sure you set it up first by useing the magnafyer near the search bar,
click it to set up how to serach.
geposted Mon 15 Apr 13 @ 7:54 pm
nm got it figure out, needed "Search in drives"
edit
seems "search in folder" doesn't work as it says
edit
geposted Fri 26 Apr 13 @ 8:34 pm
