Hi, i am setting up my rmx to stream audio live over the internet, what is the best way to get sound from vdj into the rmx sound card then back out to stream it live? If this makes sense, i am a proper noob sorry ....
geposted Fri 12 Apr 13 @ 1:44 pm
Please see here.
You will need to have VirtualDJ Broadcaster edition or Pro to be able to do this.
http://www.virtualdj.com/wiki/Broadcasting%20Howto.html
Keith
Keith
geposted Fri 12 Apr 13 @ 2:02 pm
I have installed the virtual dj pro version?
geposted Fri 12 Apr 13 @ 2:06 pm
I was going to use something like ustream to stream through if that makes a diff?
geposted Fri 12 Apr 13 @ 2:09 pm
Please register your Pro serial number on your profile page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html (Especially if you are working DJ and are making money as a result of using it at your gigs.)
Your VirtualDJ LE serial number for RMX should entitle you to a discount off the cost of upgrading (Providing that it's not second hand and has not already been used.)
geposted Sun 14 Apr 13 @ 11:43 am
