I have for years used Virtual DJ and have enjoyed it over others by far. When I took a break and just coming back to start doing what I love I seen that a few top plug ins were gone with the new update I just had it in 2012 so I no this should be something fixable. Please if there is a way I can get Overloop back I'd be happy with that . Thanks Guys
geposted Sun 21 Apr 13 @ 9:25 pm
Overloop, Vocals and Echo are PC only effects and do not exist for the Mac version and have never done so, so nothing has been taken away. If you need them, then you will need to use BootCamp to run Windows on your Mac.
In a future version of the software, Mac versions of these effects or an equivalent new effect might be available or contributed by a VDJ user who has the skills to write custom plugins. You can ask for these effects to be ported in the Wishes & New Features forum.
geposted Mon 22 Apr 13 @ 5:02 am
I'm using windows and I can't seem to find the overloop plugin as I once did? where did the overloop plugin go? thanks in advance
geposted Sat 23 Aug 14 @ 5:37 pm
