Forum: Old versions
Topic: Setting up mon configuration on MC3000 Denon
I currently have an MC3000 Denon controller with balanced outputs. Currently my settings are set to play in stereo. Outputs channel 1&2, headphones Channels 3&4. Soundcard is set to Asio driver from Denon.
What settings should I use to change this to a Mono output? I would like to use Mono in bigger rooms, where I will be adding speakers to each side (left and right).
Thanks
Frank
geposted Wed 24 Apr 13 @ 2:57 pm
Hey Frank, did you find a solution yet?
EDIT: It seems there's a "Mono" checkbox in the later versions of 7 under "advanced configuration".
