Hi guys
I need a little help. Ive just brought a hercules rmx with vdj5. I have updated all rhe drivers to run on windows 7 but when i run vdj the dexk is dead. Has anyone got any idea?
Thanks
Mark
Thanks
Mark
geposted Thu 25 Apr 13 @ 2:31 pm
What do you mean exactly by "the deck is dead" ?
Did you verify that the console is installed correctly ?
http://ts.hercules.com/faqs/eng/her_eng_00350.pdf
Did you verify that it works as a MIDI controller ?
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
If everything seems fine, then I would recommend registering the VDJ serial number in your profile, which will allow your to download the latest update (v5.2.1). The version present on the install CD might be old and not fully compatible with Windows 7 so you should install the latest version instead and see if this helps.
geposted Thu 25 Apr 13 @ 2:46 pm
When I connect fhe controller it gets power. All the drivers are ok and upto date. I will try updating vdj and see if that helps.
Regarding verifying if it works as a midi controller, ive no idea how to do that! Lol
geposted Thu 25 Apr 13 @ 2:49 pm
Ive just read the pdf's you listed and will check all that... thanks
geposted Thu 25 Apr 13 @ 3:04 pm
All checked and is now working..., thanks for your help
geposted Thu 25 Apr 13 @ 4:03 pm
JUST DOWNLOAD THE HERCULES DJ SERIES AND RUN THE SETUP .. WHEN THE INSTALLER ASK U TO PLUG THE CONSOLE DO IT AN IT AYTOMATICLY INSTALL IT BY IT SELF THEN RUN UR VIRTUAL DJ AND GO TO CONFIG DO THE ADJUSTMENTS REQUIRES :)
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=308&cid=1
geposted Sun 23 Jun 13 @ 4:49 am
