Forum: Old versions
Topic: Loading Deck A, Deck B
Hi all, Ive noticed when im loading songs onto either deck A or B the track jumps about 10/15/ sometimes 25 sec into the song after it finishes loading, the elapsed time showing not the 0.00 it should. Does anyone know why this possibly happens. Regards
geposted Thu 02 May 13 @ 11:40 am
The autocue option (Enabled by default) will automatically skip over any initial silence in the song once the song has finished loading. It will also jump to the first cue point if this is set (Saving you from having to manually cue up songs that you have already played and set previously.)
This option can be disabled in CONFIG -> Options
geposted Thu 02 May 13 @ 11:47 am
Ok thanks i'll give it a go and see how if sorts it.
geposted Fri 03 May 13 @ 3:30 am
Hi its looking so far so good, thanks guys..
geposted Fri 03 May 13 @ 3:41 am
